AG-2 Server
Ivan R. Judson
judson at mcs.anl.gov
Sun Aug 15 10:43:34 CDT 2004
If you use the -l option and the path starts with either ${pathsep} or .
It'll use the path specified, otherwise it'll go in the logs dir :-)
--Ivan
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Eric Olson
> Sent: Friday, August 13, 2004 4:14 PM
> To: ag-dev at mcs.anl.gov
> Subject: AG-2 Server
> Here's some information on the AG-2 server for those of you
> who are involved in making sure it's up.
> AG-2 is now running cvs code checked out earlier this week.
> It's setup is similar to vv2 (hume) now. To run the server,
> cd to /disks/space0/agtk.cvs/AccessGrid/bin and run "RunServer.sh"
> It's using service certs so you won't need to your own certficate.
> There are backup .cfg and .dat files in the backup directory,
> but hopefully we won't ever need them.
> Note, the OLD 2.2 Server is still a last resort backup in
> /disks/space0/ag (but i may be the only one who can start
> that), until we've successfully restarted the new one a few times.
> Also, it's creating a log that's causing the /home directory
> to run out of space all the time, but I haven't figured out
> the script fix for that yet (looks like i should use an
> absolute path for the log file name?) and the server still runs.
> Eric
