Fwd: Re: can you point me in the right direction
Robert Olson
olson at mcs.anl.gov
Wed Aug 4 10:16:16 CDT 2004
>Date: Wed, 04 Aug 2004 11:10:38 -0400
>From: Bob Riddle <bdr at internet2.edu>
>User-Agent: Mozilla Thunderbird 0.7.1 (X11/20040626)
>X-Accept-Language: en-us, en
>To: Robert Olson <olson at mcs.anl.gov>
>Cc: "Ivan R. Judson" <judson at mcs.anl.gov>
>Subject: Re: can you point me in the right direction
>X-Virus-Scanned: by mail.internet2.edu virus scanner
>X-Spam-Status: No, hits=-2.5 required=5.0
> tests=EMAIL_ATTRIBUTION,IN_REP_TO,QUOTED_EMAIL_TEXT,REFERENCES,
> REPLY_WITH_QUOTES,USER_AGENT
> version=2.55
>X-Spam-Level:
>X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
>X-Whitelist-by-bob: yes
>It lets me say "okay, go on" and then the green bar moves fills about 80%
>of the "install activity" bar and it just hangs forever. I use the task
>manager to kill it, then try to run the Venue Client ... but no node is
>ever found.
>Robert Olson wrote:
>>Does it let you just cancel out from that error?
>>At 09:24 AM 8/4/2004, Bob Riddle wrote:
>>>I decided to upgrade our onsight AG node from 2.1.something to 2.2, so I
>>>scrubbed the WinXP machine and installed the AG 2.2 stuff. I'm not
>>>having much luck getting the "Node Setup Wizard" to run ... it tells me
>>>that there is no usercert.pem in the Application Data/userid/globus
>>>directory ... which isn't surprising since the globus directory doesn't
>>>exist. It's been a while since I've done this so I must be missing
>>>something. I installed the Python stuff, the wxwindows stuff, then the
>>>AG 2.2 toolkit and tried to run the "Node Setup Wizard" with no luck. I
>>>must have left my brain in Australia ...
>>>I munged through the bugzilla stuff but didn't find anything that seemed
>>>to address this problem. Any insight, advice, or ridicule you would
>>>care to share?
>>>Bob Riddle (bdr at internet2.edu) Technologist,Internet2
>>>3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
>>>Business Phone: 734.913.4257 Fax Number: 734.913.4255
>>>"Math illiteracy affects 7 out of every 5 people"
