Shared rasmol code
Robert Olson
olson at mcs.anl.gov
Fri Oct 31 17:44:11 CST 2003
I've put a rasmol exe here:
http://www-unix.mcs.anl.gov/~olson/AG/snaps/rasmol.zip
--bob
At 05:41 PM 10/31/2003, Robert Olson wrote:
>I've got a first cut at the shared rasmol code working. This is mostly
>entirely new; I'm now using the existing mechanisms within rasmol for
>notifying clients of changes and for setting parameters, instead of adding
>new network handling code. I've just made these mods on the Windows
>version, though adding Linux support will be straightforward (as most of
>the work is in the portable section of the code).
>The python code is also structured rather differently, but is much simpler.
>Rasmol itself is in the /home/FuturesLab/Software/CVSMaster repo, module
>RasMol. The shared app is in the same repo, module SharedRasmol (yup, just
>two files).
>Performance is pretty good; with a lot of events sent there is a
>noticiable latency thru the event channel with just two clients running;
>running a test with just a TCP connection between doesn't show nearly the
>latency.
>--bob
