AGT 2.1.2 Configuration Question (fwd)
Thomas D. Uram
turam at mcs.anl.gov
Tue Oct 28 10:18:38 CST 2003
Hi Jeremy:
I can help you get your node working. The first things you should check
are:
- whether you can ping each machine from the node service machine
- whether the time is synchronized on the machines (using NTP, preferably)
If the machines are reachable and the time is synched on all the
machines, send your log files and I'll have a look. I would need to see
C:\Documents and Settings\<YOU>\Application Data\AccessGrid\agns.log
from the (windows) display machine, and ~/.AccessGrid/agsm.log from the
(linux) machine you're trying to reach.
Tom
>---------- Forwarded message ----------
>Date: Mon, 27 Oct 2003 14:55:53 -0500 (EST)
>From: stout at csee.wvu.edu
>To: olson at mcs.anl.gov
>Subject: AGT 2.1.2 Configuration Question
>I just finished upgrading the West Virginia University Access Grid to
>2.1.2. I have been trying to reconfigure the node without much success. I
>started AGNodeManager and AGServiceManager on the Windows 2000 Display
>Machine, AGServiceManager on a Linux Video Capture machine, and
>AGServiceManager on a Linux audio machine. I then run NodeSetupWizard.py
>from the Display machine. While going through the Wizard, it seems that
>the application can only communicate with the ServiceManager on the local
>machine. Every attempt to connect with any other ServiceManagers has
>failed so far.
>I tested this theory by running NodeSetupWizard.py on the other machines
>and got similar results. The video capture machine only saw its Service
>Manager and the same happened for the Audio machine.
>I have noticed that the ServiceManager application is not as verbose as it
>was in 2.1.1. In that version, the ServiceManager would indicate whether
>it had found the identity certificates or not. Whenever I start up the
>ServiceManager in 2.1.2, I get the following line:AGServiceManager URL: https://<insert hostname of machine
>here>:12000/ServiceManager.I tried running the ServiceManager in debug mode, but nothing was ever
>logged to the console.
>I ran VenueClient.py on each machine to make sure that the certficiates I
>obtained with 2.1.1 were still there. Also, I made sure to run
>grid-proxy-init on each of the Linux machines before starting the
>ServiceManager.
>Finally, I used the "Manage My Node" utility in the VenueClient to try to
>communicate with the other ServiceManagers, but I ran into the same
>problems.
>Can you offer any suggestions for troubleshooting this problem? Any help
>you can offer would be greatly appreciated. Thank you.
>Jeremy Stout
