ACLs on AG1 server
Robert Olson
olson at mcs.anl.gov
Thu Oct 23 13:47:59 CDT 2003
The admin interface is at
https://venues.accessgrid.org/anl/acls.php
This interface is ACL-oriented, as it was designed for a small number of
rooms to be managed.
To enable a particular room, one would set up the ACL, go to the ACL page,
and click "Use this ACL here" for the room down at bottom.
Tables of note:
room
ag=> \d room
Table "room"
Column | Type | Modifiers
id | integer | not null default nextval('uniqueid'::text)
name | text |
description | text |
Per-room information. id is the unique identifier, name is the room name.
room_security
ag=> \d room_security
Table "room_security"
room_id | integer |
enabled | boolean |
acl_id | integer |
If present and enabled=true, a user must be in acl acl_id to enter room
room_id.
acl
ag=> \d acl
Table "acl"
id | integer |
allowed_user | integer |
id is the acl identifier, allowed_user is the id of the user in the acl.
