Document Process Update
Robert Olson
olson at mcs.anl.gov
Thu Oct 16 00:01:52 CDT 2003
If we're looking for a comprehensive design doc for the cert mgmt stuff
that isn't what is there now, it's not going to happen by friday, as I am
gone friday and it needs more than a day's coverage; I don't see a reason
to hold up releasing because of it. A design document in the style of the
others is really a new document that I can start working up next week, in
between SC demo prep and other stuff..
--bob
At 10:45 PM 10/15/2003 -0500, Ivan R. Judson wrote:
>I've glanced over all of the documents tonight. Most of them are coming
>along quite nicely. The two that look to me to need the most work are the
>bridge server design and the certificate management design (I believe we
>need a design document for the cert stuff since it's a complicated enough
>subsystem that it warrants it). The existing design outline is a good start
>at what needs to go into the design docs; I notice the bridge server doc
>isn't using the template yet -- that needs to happen as well.
>Again, I'd like to see all of these documents done by Friday morning so that
>we can announce 2.1.2 Friday -- and the completion of these documents. The
>goal of the current design documents is also to provide a good basis for our
>next cycle, as such it should completely and accurately explain what's
>happening in the current code base.
>Thanks,
>--Ivan
>PS -- Please do read and comment on documents via ag-dev, we'll all produce
>better documents as a result.
> > -----Original Message-----
> > From: owner-ag-dev at mcs.anl.gov
> > [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Ivan R. Judson
> > Sent: Tuesday, October 14, 2003 2:03 PM
> > To: 'Robert Olson'; ag-dev at mcs.anl.gov
> > Subject: RE: Document Process Update
> > I forgot to mention that we should all be reading and
> > commenting (via email) on each others docs so we can make
> > them high quality as fast as possible.
> > --Ivan
> > > From: Robert Olson [mailto:olson at mcs.anl.gov]
> > > Sent: Tuesday, October 14, 2003 1:38 PM
> > > To: judson at mcs.anl.gov; ag-dev at mcs.anl.gov
> > > Subject: Re: Document Process Update
> > > I think I'm up to date on manuals, given that:
> > > I don't see what it means for cert mgmt and access control
> > > documents to be
> > > merged; they address different topics, and
> > > Right now, I think it's more important to make headway on
> > > apps stuff for SC
> > > demos than to convert over the datastore doc from tex/pdf to
> > > word; when the
> > > programmer's manual activity gains traction I'll get it
> > > switched over, and
> > > will thus only have to reformat once.
> > > --bob
> > > At 05:07 PM 10/3/2003 -0500, Ivan R. Judson wrote:
> > > >Howdy,
> > > >We currently have a few types of documents:
> > > >Architecture Documents (These should all be word docs, with visio)
> > > >Design Documents (These should all be word docs, with visio)
> > > > (Example Outline in
> > > DesignOutline.doc and
> > > >Template in AGDesign.dot)
> > > >How-To Documents (These should all be word docs)
> > > >Implementation Notes (These can be anything, they aren't
> > for public
> > > >consumption really,
> > > > but remember, not everyone
> > > has every
> > > >tool...I don't have latex,
> > > > I do have pdf :-)
> > > >Manuals (These should all be in word)
> > > >In order to close our last few issues on this cycle, I'd
> > > like us to get
> > > >our design documents in synch with our current code. In
> > > order for that
> > > >to happen, I'd like it if the following writing assignments were
> > > >completed by the end of next week:
> > > >Document Author Action
> > > >Virtual Venues Design Ivan Incorporate
> > > Event Service
> > > >doc
> > > >Venue Client Design Susanne Incorporate Personal
> > > Node Design
> > > >Venue Management Design Susanne
> > > >Data Store Design Eric
> > > >Bridge Server Design Tom
> > > >Node Management Design Tom Incorporate
> > > Personal Node
> > > >Design
> > > >Certificate Management Bob Merge
> > > >and Access Control Notes
> > > >Datastore Client Bob
> > > Converted to word,
> > > >to be part of future programmers manual.
> > > >Toolkit Core Design Ivan Convert
> > > Toolkit config and
> > > >init doc
> > > >Looking at CVS, we have more documents than this, which is
> > good ;-).
> > > >But, we do need to consolidate some, the documents that are being
> > > >merged can be removed from cvs. If there are remaining
> > > implementation
> > > >details that would be lost, they should be put in an implementation
> > > >notes document.
> > > >Thanks, we're so close to finishing this cycle I can taste it :-)
> > > >--Ivan
