speaking of multicast debugging...
Robert Olson
olson at mcs.anl.gov
Thu May 8 10:35:26 CDT 2003
Here is the paper trail of the process that led to the repair of the ANL to
Germany multicast path. Note that the debugging was the minor part; it took
more time to bring together the 4-5 different institutions that
participated in finding the solution.
--bob
Date: Tue, 6 May 2003 09:21:58 -0500 (CDT)
To: mcast-support at accessgrid.org
Subject: Multicast problem: MCS -> Germany
Message-ID: <Pine.LNX.4.44.0305060919000.22019-100000 at terra.mcs.anl.gov>
MIME-Version: 1.0
Content-Type: TEXT/PLAIN; charset=US-ASCII
X-Spam-Status: No, hits=0.5 required=5.0 tests=X_NOT_PRESENT version=2.21
X-Spam-Level:
Sender: owner-mcast-support at accessgrid.org
Precedence: bulk
X-Whitelist-by-bob: yes
The following traffic isn't going thru:
Sender: 140.221.34.33 or 140.221.8.41
Receiver: 134.94.106.106
Group: 233.4.200.3/19004
The other direction works, and that receiver appears to be getting traffic
fine from other sites in the group (NCSA, BU, Manchester).
--bob
Date: Tue, 6 May 2003 09:56:57 -0500 (CDT)
cc: m.sczimarowsky at fz-juelich.de
Subject: Re: Multicast problem: MCS -> Germany
In-Reply-To: <Pine.LNX.4.44.0305060919000.22019-100000 at terra.mcs.anl.gov>
Message-ID: <Pine.LNX.4.44.0305060946480.22019-100000 at terra.mcs.anl.gov>
MIME-Version: 1.0
X-Spam-Status: No, hits=-3.9 required=5.0 tests=IN_REP_TO,X_NOT_PRESENT
version=2.21
X-Spam-Level:
Precedence: bulk
[Martin, can you forward to an appropriate network admin on your
side?]
Looking at nycmng, which is the last abilene hop before GEANT:
(terra) % traceroute 134.94.106.106
traceroute to 134.94.106.106 (134.94.106.106), 30 hops max, 38 byte
packets
1 hsrp (140.221.11.253) 0.402 ms 0.237 ms 0.215 ms
2 guava-stardust.anchor.anl.gov (130.202.222.74) 0.366 ms 0.247 ms
0.245 ms
3 mren-anl-gige.anchor.anl.gov (192.5.170.214) 0.829 ms 0.852 ms
0.806 ms
4 chin-mren-ge.abilene.ucaid.edu (198.32.11.97) 0.911 ms 0.875 ms
0.845 ms
5 nycmng-chinng.abilene.ucaid.edu (198.32.8.83) 20.892 ms 29.235 ms
20.898 ms
6 abilene.uk1.uk.geant.net (62.40.103.25) 171.524 ms 171.594 ms
171.247 ms
7 uk.fr1.fr.geant.net (62.40.96.89) 151.401 ms 151.157 ms 151.500 ms
8 fr.de1.de.geant.net (62.40.96.49) 151.641 ms 151.412 ms 151.539 ms
9 * * *
10 cr-frankfurt1-po8-2.g-win.dfn.de (188.1.80.37) 151.903 ms 151.742 ms
151.698 ms
11 cr-koeln1-po0-1.g-win.dfn.de (188.1.18.86) 155.954 ms 155.976 ms
157.099 ms
12 ar-aachen1-po1-0.g-win.dfn.de (188.1.84.50) 157.514 ms 157.658 ms
158.299 ms
13 zam301.zam.kfa-juelich.de (134.94.111.238) 158.004 ms 158.166 ms
157.692 ms
14 * * *
Querying NYCMng [New York, New York]: msdp source-active group 233.4.200.3
Group address Source address Peer address Originator Flags
233.4.200.3 140.221.34.33 198.32.8.196 192.5.170.2 Accept
134.55.3.3 192.5.170.2 Reject
193.10.68.85 192.5.170.2 Reject
199.109.5.1 192.5.170.2 Reject
Querying NYCMng [New York, New York]: pim join 233.4.200.3 extensive
Instance: PIM.master Family: INET
Group: 233.4.200.3
Source: 140.221.34.33
Flags: sparse
Upstream interface: so-0/0/0.0
Upstream State: Local RP, Join to Source
Keepalive timeout: 181
Downstream Neighbors:
Interface: so-2/3/0.0
192.5.89.9 State: Join Flags: S Timeout: 193
Looks like perhaps missing joins from the GEANT side? A working source
looks like this:
Group: 233.4.200.3
Source: 141.142.66.75
Flags: sparse
Keepalive timeout: 204
Interface: so-2/2/0.0
62.40.103.25 State: Join Flags: S Timeout: 209
192.5.89.9 State: Join Flags: S Timeout: 183
--bob
> --bob
X-Sender: olson at pop.mcs.anl.gov
X-Mailer: QUALCOMM Windows Eudora Version 5.2.0.9
Date: Tue, 06 May 2003 10:53:32 -0500
Cc: m.sczimarowsky at fz-juelich.de
In-Reply-To: <Pine.LNX.4.44.0305060946480.22019-100000 at terra.mcs.anl.gov
References: <Pine.LNX.4.44.0305060919000.22019-100000 at terra.mcs.anl.gov>
Mime-Version: 1.0
Content-Type: text/plain; charset="us-ascii"; format=flowed
X-Spam-Status: No, hits=-4.4 required=5.0 tests=IN_REP_TO version=2.21
X-Spam-Level:
Precedence: bulk
I am now seeing a similar situation with:
source 140.221.34.34
receiver 192.150.184.66
group 233.2.171.251/59988
where the ANL->Manchester traffic does not go through. Again, on nycmng a
show pim going shows a missing join toward geant for the 140.221.34.34 source.
--bob
Date: Tue, 06 May 2003 12:38:05 -0500
To: operations at dante.org.uk
Subject: Multicast problem from Argonne National Laboratory to Juelich
Cc: mcast-support at accessgrid.org, m.sczimarowsky at fz-juelich.de
Mime-Version: 1.0
Content-Type: text/plain; charset="iso-8859-1"; format=flowed
Content-Transfer-Encoding: 8bit
X-MIME-Autoconverted: from quoted-printable to 8bit by mcs.anl.gov id
h46Hc7t143844
X-Spam-Status: No, hits=0.0 required=5.0 tests= version=2.21
X-Spam-Level:
Precedence: bulk
Hello --
I am trying to track down a problem with multicast routing between a
machine at Argonne National Laboratory in the US with a machine at the
Forschungszentrum Jülich.
The following traffic isn't going through:
A traceroute from ANL to the Jülich machine looks like this:
traceroute to 134.94.106.106 (134.94.106.106), 30 hops max, 38 byte packets
1 hsrp (140.221.11.253) 0.362 ms 0.276 ms 0.217 ms
2 guava-stardust.anchor.anl.gov (130.202.222.74) 0.305 ms 0.235
ms 0.223 ms
3 mren-anl-gige.anchor.anl.gov (192.5.170.214) 2.173 ms 0.875 ms 0.798 ms
4 chin-mren-ge.abilene.ucaid.edu (198.32.11.97) 0.909 ms 0.867
ms 0.863 ms
5 nycmng-chinng.abilene.ucaid.edu (198.32.8.83) 33.148 ms 20.940
ms 20.982 ms
6 abilene.uk1.uk.geant.net (62.40.103.25) 171.763 ms 171.916
ms 171.701 ms
7 uk.fr1.fr.geant.net (62.40.96.89) 151.610 ms 152.076 ms 151.510 ms
8 fr.de1.de.geant.net (62.40.96.49) 152.223 ms 151.415 ms 151.269 ms
9 * * *
10 cr-frankfurt1-po8-2.g-win.dfn.de (188.1.80.37) 151.739 ms 152.068
ms 151.766 ms
11 cr-koeln1-po0-1.g-win.dfn.de (188.1.18.86) 155.971 ms 157.902
ms 155.772 ms
12 ar-aachen1-po1-0.g-win.dfn.de (188.1.84.50) 157.484 ms 157.541
ms 157.526 ms
13 zam301.zam.kfa-juelich.de (134.94.111.238) 158.034 ms 157.818
ms 158.415 ms
14 * * *
15 * * *
16 * * *
Looking at the NYCMNG Abilene router proxy, I find this:
Group: 233.4.200.3
Flags: sparse
It appears that the join is missing toward geant.net; a working source
(from earlier today) showed this state at NYCMNG:
Group: 233.4.200.3
Flags: sparse
Please let me know if there is any more information I can give you, or if
there is a better location to which this report can be sent.
Thank you,
--bob
Date: Wed, 07 May 2003 07:10:46 -0500
Subject: Fwd: Re: Multicast problem
Mime-Version: 1.0
X-Spam-Level:
Precedence: bulk
>Date: Wed, 07 May 2003 12:52:53 +0200
>From: "M.Sczimarowsky" <M.Sczimarowsky at fz-juelich.de>
>Organization: Forschungszentrum Juelich GmbH
>X-Mailer: Mozilla 4.75 [en] (X11; U; SunOS 5.8 sun4u)
>X-Accept-Language: en
>To: Robert Olson <olson at mcs.anl.gov>
>X-Spam-Status: No, hits=0.5 required=5.0 tests=FROM_NAME_NO_SPACES
>version=2.21
>X-Spam-Level:
>Hi Bob,
>here is the traceroute 140.221.34.3 result from
>ag-audio.zam.kfa-juelich.de,
>although I dont see that this helps much, I am quite sure the multicast
>routing is different. I will try to find it out. I passed your info
>to our networking experts. Thanks very much for your help.
>Martin
>ag-audio:~ # traceroute 140.221.34.3
>traceroute to 140.221.34.3 (140.221.34.3), 30 hops max, 40 byte packets
> 1 zam047-106.zam.kfa-juelich.de (134.94.106.1) 1 ms 0 ms 0 ms
> 2 zam301-p2p.zam.kfa-juelich.de (134.94.111.186) 0 ms 0 ms 0 ms
> 3 ar-aachen1.g-win.dfn.de (188.1.43.193) 1 ms 1 ms 1 ms
> 4 cr-koeln1-po2-0.g-win.dfn.de (188.1.84.49) 4 ms 3 ms 3 ms
> 5 cr-frankfurt1-po9-1.g-win.dfn.de (188.1.18.85) 7 ms 7 ms 7 ms
> 6 so-6-0-0.ar2.FRA2.gblx.net (208.48.23.141) 7 ms 7 ms 7 ms
> 7 pos5-0-2488M.cr2.FRA2.gblx.net (62.16.32.77) 7 ms 7 ms 7 ms
> 8 so2-0-0-2488M.cr1.PAO2.gblx.net (208.51.224.210) 153 ms 153 ms
>153 ms
> 9 so-5-0-0-2488M.br2.PAO2.gblx.net (208.51.224.142) 153 ms 153 ms
>153 ms
>10 208.50.13.54 (208.50.13.54) 154 ms 154 ms 154 ms
>11 snv-paix-pa.es.net (134.55.208.206) 154 ms 154 ms 155 ms
>12 snvcr1-ge0-snvrt1.es.net (134.55.209.89) 155 ms 156 ms 155 ms
>13 chicr1-oc192-snvcr1.es.net (134.55.209.54) 203 ms 204 ms 202 ms
>14 anl-oc12-chicr1.es.net (134.55.209.202) 209 ms 206 ms 213 ms
>15 guava-esnet.anchor.anl.gov (192.5.170.77) 157 ms 157 ms 157 ms
>16 stardust-guava.anchor.anl.gov (130.202.222.73) 157 ms 157 ms 158
>ms
>17 ws-audio.mcs.anl.gov (140.221.34.3) 158 ms 157 ms 157 ms
>Robert Olson wrote:
> > Hi --
> > It looks like we've exhausted the debugging we can do from this end; we'll
> > need to get someone from either your site or the GEANT network folks to
> > look into it.
> > One thing you can do is send us the result of a tracroute from your audio
> > machine to 140.221.34.33.
> > thanks,
> > --bob
>_______________________________________________________________________
> Martin Sczimarowsky
> Forschungszentrum Juelich / Zentralinstitut fuer Angewandte Mathematik
> D 52425 Juelich Tel/Fax : +49 2461 61 6411/6656
>_______________________________ M.Sczimarowsky at fz-juelich.de __________
X-Sender: ana at mail.dante.org.uk
X-Mailer: QUALCOMM Windows Eudora Version 4.3.1
Date: Wed, 07 May 2003 14:21:10 +0100
To: multicast at noc.geant.net
Subject: Re: Multicast problem from Argonne National Laboratory to
Juelich
Cc: mcast-support at accessgrid.org, m.sczimarowsky at fz-juelich.de,
Robert Olson <olson at mcs.anl.gov>, operations at dante.org.uk,
noc at noc.geant.net
In-Reply-To: <5.2.0.9.2.20030506123053.0163eec8 at pop.mcs.anl.gov>
Mime-Version: 1.0
X-Spam-Level:
Hi NOC,
could you help Mr. Olson to debug this multicast problem?
regards,
ana
At 12:38 06/05/2003 -0500, Robert Olson wrote:
>Hello --
> ms 0.223 ms
> ms 0.798 ms
> ms 0.863 ms
> ms 20.982 ms
> ms 171.701 ms
> 9 * * *
>ms 151.766 ms
>ms 155.772 ms
>ms 157.526 ms
>ms 158.415 ms
>14 * * *
>15 * * *
>16 * * *
>Group: 233.4.200.3
> Flags: sparse
>Group: 233.4.200.3
> Flags: sparse
>Thank you,
>--bob
From: "GEANT MULTICAST" <multicast at noc.geant.net>
To: "Robert Olson" <olson at mcs.anl.gov>,
"Abilene Network Operations Center" <noc at abilene.iu.edu>
Cc: <mcast-support at accessgrid.org>, <m.sczimarowsky at fz-juelich.de>,
<operations at dante.org.uk>, "Ana Romero" <Ana.Romero at dante.org.uk>,
References: <4.3.1.0.20030507141932.022b1810 at mail.dante.org.uk>
Subject: Re: Multicast problem from Argonne National Laboratory to Juelich
Date: Wed, 7 May 2003 16:38:20 +0200
MIME-Version: 1.0
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 6.00.2600.0000
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2600.0000
X-Spam-Level:
Hi Robert,
The thing is that we receive well your source active (SA) MSDP from Abilene
network (AS11537) but our router (UK POP) reject it because your prefix
140.221.0.0/16 is not receive by the same gateway . In fact we received this
prefix via Global Crossing Network (AS3549). So you can create the RP tree.
Please find below :
admres at uk1.uk.re0> show msdp source-active group 233.4.200.3
233.4.200.3 140.221.34.33 62.40.103.26 192.5.170.2 Reject
146.97.36.13 192.5.170.2 Reject
233.4.200.3 192.73.7.34 62.40.103.26 134.55.200.25 Accept
To the Abilene NOC : Could you please have a look at this routing problem
(?) and get back to us as soon as you get some news ?
Best Regards,
Jean-Luc HELION
Network Engineer
GEANT NOC
Tel : +33 1 4313 8108
Fax : +33 1 4078 6400
Email :
trouble at noc.geant.net -- to report network problems
help at noc.geant.net -- to request help/information
abuse at noc.geant.net -- to report network abuse
----- Original Message -----
To: <multicast at noc.geant.net>
Cc: <mcast-support at accessgrid.org>; <m.sczimarowsky at fz-juelich.de>; "Robert
Olson" <olson at mcs.anl.gov>; <operations at dante.org.uk>; <noc at noc.geant.net>
Sent: Wednesday, May 07, 2003 3:21 PM
Hi NOC,
regards,
ana
>Hello --
> ms 0.223 ms
> ms 0.798 ms
> ms 0.863 ms
> ms 20.982 ms
> ms 171.701 ms
> 9 * * *
>ms 151.766 ms
>ms 155.772 ms
>ms 157.526 ms
>ms 158.415 ms
>14 * * *
>15 * * *
>16 * * *
>Group: 233.4.200.3
> Flags: sparse
>Group: 233.4.200.3
> Flags: sparse
>Thank you,
>--bob
Date: Wed, 07 May 2003 15:45:17 -0500
To: Jon-Paul Herron <jpherron at iu.edu>, <multicast at noc.geant.net>
Subject: Re: Abilene - Geant not receiving ANL multicast prefixes
ENTRY=3567
Cc: <Ana.Romero at dante.org.uk>, <perations at dante.org.uk>,
<m.sczimarowsky at fz-juelich.de>, mcast-support at accessgrid.org
In-Reply-To: <BADED983.2184%jpherron at iu.edu>
Mime-Version: 1.0
X-Spam-Level:
Precedence: bulk
Very cool!
Martin - can you restart your rat on 233.4.200.3/19004 so we can see if the
traffic is flowing again?
thanks,
--bob
At 03:40 PM 5/7/2003 -0500, Jon-Paul Herron wrote:
>I took a look at the issue that was preventing Geant host from receiving
>multicast traffic from ANL. It looks like the issue was that we were
>preventing all ANL (and other Fednets) prefixes, both unicast and multicast
>from being advertised to ITNs. I've changed this to allow all multicast
>prefixes to flow freely to ITNs and Fednets, sinc multicast is AUP-free on
>Abilene. Can you verify that there is no longer a problem?
Date: Thu, 08 May 2003 06:50:07 -0500
ENTRY=3567
Mime-Version: 1.0
X-Spam-Level:
Precedence: bulk
Traffic from ANL is indeed now flowing to Julich, as verified by the
application. Thank you to all for helping resolve this.
--bob
62.40.102.47 192.5.170.2 Reject
62.40.103.25 192.5.170.2 Reject
Group: 233.4.200.3
Flags: sparse
Keepalive timeout: 182
Querying NYCMng [New York, New York]: multicast route group 233.4.200.3
source-prefix 140.221.34.33/32 extensive
Family: INET
Group Source prefix Act Pru NHid Packets IfMismatch Timeout
233.4.200.3 140.221.34.33 /32 A F 368 338331 0 360
Session name: Static Allocations
Forwarding rate: 36 kBps (101 pps)
