update
Ti Leggett
leggett at mcs.anl.gov
Tue Mar 11 21:40:31 CST 2003
Here's what I got accomplished tonight:
WinGlobus is now in cvs. Module name: WinGlobus
It should have all the WinGlobus stuff cleaned and ready to build as
well as the globus setup py files and the iss files. To build WinGlobus
you have to first clean both the threaded and non threaded lib
solutions, delete all the globus*.lib in /lib. Then you build the non
threaded solution, then you rebuild gssapi. Then you build the threaded
solution.
In order to make a windows installer you'll need pyglobus and pydns.
NOTE: after rebuilding wgpi now dies horribly so there will be more
debugging tomorrow.
I also fixed the generate a certificate certreq.cmd and ssleay.conf
files so they actually work.
I also changed everything to use AppDate\globus instead of .globus
I also cleaned up the Prebuild.cmd script so it's a bit easier to change
to build installers on others machines.
I also added version numbers to the installer exectuable.
On the AG side of things.
- I cleaned up and fixed the makeServiceZips.py file
- Cleaned up the Prebuild.cmd and iss files
- Rebuilt ag-rat with VS.NET thanks to Ivan's fixes
- Rebuilt ag-vic with VS.NET thanks to Ivan's fixes and also fixed some
project depenedencies which I haven't commited yet. ag-vic was also
built without the intel jpeg library though to really fix we need to
remove some files out of CVS.
- Made it so py files are copied to pyw files and pointed the icons and
shortcuts at those instead
I probably did a few other things but can't remember right now.
I'm going home.
