June 19 Testing Notes
Mary Fritsch
fritsch at mcs.anl.gov
Thu Jun 26 19:07:03 CDT 2003
June 19
NCAR (Darin Oman)
stability to server needed to full time use... testing Shared Browser was
done at end of meeting.
J&J (Lisa)
wanted to test shared presentation application... have folks testing
software daily.
LBNL (Mike Elmore)
AG node versus individual participant was discussed... certificates can be
copied for each machine rather than using individual participant certificates.
General Testing Notes
A bit of information regarding mailcap files, where they should be located,
what there purposes are, was discussed.
So a few things were tested regarding applications. NCAR, ANL (2 nodes)
used the Shared Browser. Users realized that the URL does not
scroll. Folks also realized that popup ads and animated websites can cause
the application to fail. As you know anyone can type in a URL and take
control per se of the app. Some of the popups and animations crashed the
app to the extent of not being able to regain sync to a link someone added.
As a further test we tried typed in a URL that linked direction to a ppt
file and see if advancement of slides could happen. This failed. Of
course, this app doesn't wasn't intended for this.. but we were just
checking out things.
Eric also ran quick Shared Presentation app and J&J joined this successfully.
