crash
Robert Olson
olson at mcs.anl.gov
Fri Jan 31 09:32:55 CST 2003
I got this when I copied state from moonbeam to vv2; I think the problem is
the client profile was trying to use the old server address and failing hard.
It's not clear where the client profile is kept..
--bob
[olson at vv2 ~/AccessGrid]$ !?Client
python2 bin/VenueClient.py
creating proxy on https://localhost:8000/VenueServer ioattr
is <pyGlobus.io.TCPIOAttr instance at 0x868c36c>
Traceback (most recent call last):
File "bin/VenueClient.py", line 214, in ?
vc.ConnectToServer(profile)
File "bin/VenueClient.py", line 32, in ConnectToServer
venueUri = Client.Handle( venueServerUri ).get_proxy().GetDefaultVenue()
File "/home/olson/AccessGrid/AccessGrid/hosting/pyGlobus/AGGSISOAP.py",
line 3645, in __r_call
self.__hd, self.__ma)
line 3563, in __call
config = self.config)
File "/home/olson/AccessGrid/AccessGrid/hosting/pyGlobus/Client.py",
line 122, in call
r.putrequest("POST", real_path)
File "/usr/lib/python2.2/httplib.py", line 452, in putrequest
self.send(str)
File "/usr/lib/python2.2/httplib.py", line 394, in send
self.connect()
File "/usr/lib/python2.2/site-packages/pyGlobus/io.py", line 1074, in
connect
self.sock.connect(self.host, self.port, self.io_attr)
File "/usr/lib/python2.2/site-packages/pyGlobus/io.py", line 658, in connect
raise ex
pyGlobus.io.GSITCPSocketException: a system call failed (Connection refused)
