QuickBridge for AG 2.0
Thomas Uram
turam at mcs.anl.gov
Thu Jan 30 13:15:42 CST 2003
Hi Stephen:
Sorry it took me longer than expected to respond. We've been entrenched
in AG2 development, and this topic needed some thought before I could
respond. See the responses to your questions below.
As for developing the QuickBridge service, you could start by looking at
the services that exist in the repository, e.g. AudioService and
VideoProducerService. These examples do most of their work by
overriding the Start method to actually start rat/vic. In the case of
the QuickBridge service, the Start method would probably just set the
"started" flag. The bulk of the work would be done in a method
"Bridge", which would accept a list of multicast addresses/ports,
allocate a port and start a bridge for each one, and return a list of
(unicast) addresses/ports. The pids of the quickbridge processes need
to be stored, so the Stop method can kill them.
This should give you a basic impression of how the quickbridge service
will look. There are other issues that will have to be dealt with, like
what to do with bridged users when the user running the bridge leaves
the venue, but we can talk about that later. Meanwhile, let me know if
you have questions.
Tom
S.Booth wrote:
>OK I think I'm prepared to take on ownership of this.
>I have had a quick look at the CVS repository. There does not seem to be a
>bridging service there just yet but I get the basic idea from looking at
>the others.
>There are a number of things I want to do with the QB code and I'm
>keen that we end up with something that does what AG2.0 wants.
>I guess the rest of this email is really qestions for Tom.
>Who is authorised to request that an AG node starts a bridge and who
>is authorised to use that bridge once it is started?
>How integrated will the bridge service be with the web interface.
Nodes will maintain a list of administrators and an access policy.
Administrators can control who has access to the bridge service through
the access policy. Node operators can grant access to users in the venue.
The authorization model for AG2 is still in development. The alpha will
support very limited access control and, therefore, might be disabled by
default. This means that users in the venue would have access to the
bridge service.
>At the moment QB detects unicast clients by detecting the RTCP control
>packets from vic/rat and sends a unicast data-stream to each IP
>address it has seen packets from. Would it be better to have the AG
>service manage the list of clients.
If access to the bridge is controlled by the AG software, we may not
need to manage a list of clients of the quickbridge service.
>Do we want to have Send-only(cameras) Recv-only(Display) and
>Send-recv(audio) forwarding. This would save bandwidth and is fairly
>easy to do especially if the AG service is managing the client-list or
>I could have seperate unicast ports for the different modes of operation.
For now, integrating the current QuickBridge functionality into the
AccessGrid will be a big win.
There are probably improvements that could be made in bridging. Ivan
has been looking at UMTP (e.g., live.com), thinking this might be a good
direction to head in the future. We should look at these for beyond
AG2.0.
>Do we want the option to use a single bridge to forward both the video
>and audio streams (I think this would perform better than trying to
>run 2 QB processes on a single CPU).
Might be better in the long run, but we could start by just wrapping the
existing QuickBridge functionality as an AG node service.
>Do you want to support decryption/re-encryption in the bridge.
I don't see that this functionality would be required, so we probably
don't need to deal with it now. In what circumstances do you think this
would be useful?
>Do we want bandwidth limitation in the bridge.
Eventually, I think we would.
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030130/253e12e2/attachment.htm>
