RPMS and SRPMS
Thomas Uram
turam at mcs.anl.gov
Fri Feb 28 16:56:09 CST 2003
Ivan:
I rebuilt the 2.0alpha4 RPMS and SRPMS below and copied them to the
software directory. I assume you'll copy over the windows installer
that you built locally and update the web pages.
Ti: I had to steal the 2.0alpha-4 directory from you to copy the files,
resulting in a 2.0alpha-4_tiCanRemove directory, which you should remove.
RPMS
AccessGrid-2.0alpha-4.i386.rpm
AccessGrid-AudioService-2.0alpha-4.i386.rpm
AccessGrid-VenueClient-2.0alpha-4.i386.rpm
AccessGrid-VenueServer-2.0alpha-4.i386.rpm
AccessGrid-VideoConsumer-2.0alpha-4.i386.rpm
AccessGrid-VideoProducer-2.0alpha-4.i386.rpm
SRPMS
AccessGrid-2.0alpha-4.src.rpm
Tom
