FW: [Boa Constr] SSHExplorer
Ivan R. Judson
judson at mcs.anl.gov
Tue Feb 4 07:09:16 CST 2003
This might help us track down a secure remote file browser (or leverage
one).
--Ivan
> -----Original Message-----
> From: boa-constructor-users-admin at lists.sourceforge.net
> [mailto:boa-constructor-users-admin at lists.sourceforge.net] On
> Behalf Of Rasjid Wilcox
> Sent: Tuesday, February 04, 2003 6:45 AM
> To: Riaan Booysen
> Cc: boa-constructor-users at lists.sourceforge.net
> Subject: Re: [Boa Constr] SSHExplorer
> On Sun, 5 Jan 2003 1:46 pm, Riaan Booysen wrote:
> > Hi Rasjid,
> > > A very very belated response to this...
> > No problem, glad you did in the end.
> > > On Wed, 30 Oct 2002 8:30 pm, Riaan Booysen wrote:
> > > > Personally I don't want to tie Boa to cygwin. Can't
> your library
> > > > also use a single ssh.exe/scp.exe setup. (I can mail
> these exes to
> > > > you if you don't have them)
> > > I'd rather know the source of these non-putty, non-cygwin
> > > executables, as the putty ones do not work well with
> PySSH, and I'd
> > > like to see if these do.
> > Not exactly sure about the sources for the exes, inside
> them is a BSD
> > copyright notice.
> > I suspect it's just the OpenSSH sources (of a while back) compiled
> > with MinGW.
> After some searching, I've found what I think is the sources for the
> executables (or rather, patches against the original
> sources). As for the
> actual sources, I'm hoping that a linux source rpm of the
> same version will
> have the original sources intact.
> All up, it appears that the binaries are openssh 1.2.14. The only
> instructions I could find on compiling uses VC++6.0 through a
> Cygwin shell,
> not MinGW.
> Anyway, I'm much happier now that I know where these come
> from and roughtly
> what they are. I'd be happier still if I could find such a
> thing for a more
> recent version of ssh.
> Cheers,
> Rasjid.
> Rasjid Wilcox
> Canberra, Australia (UTC +10 hrs)
> http://www.openminddev.net
> This SF.NET email is sponsored by:
> SourceForge Enterprise Edition + IBM + LinuxWorld = Something
> 2 See! http://www.vasoftware.com
> Boa-constructor-users mailing list
> Boa-constructor-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/boa-constructor-users
