Fwd: [Pywebsvcs-talk] Announce: SOAPpy 0.11.0
Ivan R. Judson
judson at mcs.anl.gov
Mon Dec 22 08:02:13 CST 2003
This means we can use the stock SOAPpy -- I'll verify this with Greg :-)
--Ivan
Begin forwarded message:
> From: "Warnes, Gregory R" <gregory_r_warnes at groton.pfizer.com>
> Date: December 19, 2003 9:34:22 PM CST
> To: "'pywebsvcs-talk'" <pywebsvcs-talk at lists.sourceforge.net>
> Subject: [Pywebsvcs-talk] Announce: SOAPpy 0.11.0
> Release 0.11.0 of SOAPpy
> - New/Changed configuration settings:
> - Config.simplify_objects=1 now converts all SOAPpy objects into
> basic
> Python types (list, dictionary, tuple, double, float, etc.). By
> default,
> Config.simplify_objects=0 for backward compatibility.
> - Config.dict_encoding='ascii' converts the keys of dictionaries
> (e.g. created when Config.unwrap_results=1) to ascii == plain python
> strings instead of unicode strings. This variable can be set to any
> encoding known to string.encode().
> - Config.strict_range=1 forces the SOAP parsing routines to perform
> range checks on recieved SOAP float and double objects. When
> Config.strict_range=0, the default, parsing does not perform range
> checking (except for detecting overflows, which always occurs). In
> either case, range checking is performed when
> generating SOAP float and double objects.
> - Fixes for WSDLProxy.
> - Scripts in the test/ directory
> - Verbose debugging messages have been turned off..
> - SOAPtest.py now functions when Config.unwrap_results=1
> - SOAPtest.py now sets Config.strict_range=1 so that range
> checks are be properly tested.
> - New README file listing what test scripts fail and why.
> - Initial support for Globus via pyGlobus contributed by Ivan
> R. Judson <judson at mcs.anl.gov>.
> Gregory R. Warnes, Ph.D.
> Senior Coordinator
> Groton Non-Clinical Statistics
> Pfizer Global Research and Development
> <<Warnes, Gregory R.vcf>>
> LEGAL NOTICE
> Unless expressly stated otherwise, this message is confidential and
> may be privileged. It is intended for the addressee(s) only. Access to
> this E-mail by anyone else is unauthorized. If you are not an
> addressee, any disclosure or copying of the contents of this E-mail or
> any action taken (or not taken) in reliance on it is unauthorized and
> may be unlawful. If you are not an addressee, please inform the sender
> immediately.
Name: Warnes, Gregory R.vcf
Type: text/directory
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20031222/38056c4d/attachment.bin>
