Firewall document
Thomas D. Uram
turam at mcs.anl.gov
Mon Dec 8 15:14:19 CST 2003
A few more comments:
"When the term connection is used it is meant to mean a GSI Secured TCP
Socket"
* Grammar complaint: Change to "The term 'connection' refers to a
GSI Secured TCP Socket"
The port tables confuse me.
* I think there should be two tables: one for "minimal ports
necessary to make things work", and one for optional ports.
In the table under the text "These services make no /wide area/ network
connections, but do require any firewall on the local machine be
configured appropriately"
* "Services" should say that they use dynamically assigned ports.
Ivan R. Judson wrote:
>Here's what I have; if there's nothing more to add, this should be
>sufficient for the APS folks.
>I'd like Bob and Tom to read it over and verify there's nothing missing. The
>APS folks are waiting for this document and I'd like it out the door today.
>--Ivan
> Firewall Configuration Information for AGTk 2.0
> Author: Ivan R. Judson
> Status: Draft
> Contact: ag-info at mcs.anl.gov <mailto:ag-info at mcs.anl.gov>
> Copyright: University of Chicago, 2003
> Date: 04-12-2003
> Abstract
> This document specifies what firewall configuration options need to be
> considered to use the Access Grid in a firewalled network environment.
> Specific firewall solutions are not addressed in this document.
> Copyright
> This document falls under the AGTkPL.
> Discussion
> The Access Grid Toolkit provides distributed collaboration system with
> parts that communicate over both the local area and wide area network.
> In order to function properly the various parts of the system need to
> be able to initiate and use network connections in various directions
> (both incoming and outgoing). When the term connection is used it is
> meant to mean a GSI Secured TCP Socket.
> For the streaming media, which is carried via RTP, two ports are
> required. The first (even numbered) port is the data port, the next
> odd port (first port + 1) is used for RTP Control data.
> In the current version of the toolkit, the network interfaces are
> served via SOAP. These interfaces are exposed on:
> Service Default Port(s)
> Services dynamically assigned
> Service Manager 11000
> Node Service 12000 and 1 dynamically assigned
> Venue Client ^* <#id3> /optional/ 1 dynamically assigned
> Venue Server 8000, 8002, 8004, 8006
> Bridge Server Each stream is statically configured or dynamically
> assigned
> Beacon Server (233.4.200.21, 10002/10004), beacon.dast.nlanr.net:10004
> The following services need special configuration to operate correctly.
> Venue Client /optional/ 1 dynamically assigned
> assigned
> These services make no /wide area/ network connections, but do require
> any firewall on the local machine be configured appropriately ^+ <#id4>.
> Services none
> [*] <#id1> Disabling incoming connections to the Venue Client is
> possible and doesn't significantly hinder collaboration. Personal data
> sharing is not possible if incoming connections are not allowed.
> [+] <#id2> Host based firewalls like Microsofts XP Firewall will
> interfere not only with local area connectivity but it will also stop
> multicast from working properly. Currently, the best advice is to turn
> the firewall off.
> Service Details
> Venue Server (defaults to port 8000, 8002, 8004, 8006)
> The venue server listens for incoming connections on four ports,
> which are configurable. These ports are for incoming connections
> only, there are no outbound connections from the venue server.
> Bridge Server (multiple ports used)
> The bridge server can use either statically assigned ports for
> the media bridges it starts, or it can dynamically assign the
> ports for media bridges.
> Beacon Server (one group, one outgoing connection)
> The beacon server uses one multicast group and one outbound
> connection to a reporting server. These are both configurable,
> but the defaults are the correct configuration to be a part of
> the Access Grid Multicast Beacon infrastructure.
> Multicast
> In order for audio and video to flow among users multicast needs to be
> able to be allowed through the firewall. There is currently no set of
> static configurations that are used for multicast (although they could
> be used, if needed), so ideally the firewall would allow data from any
> group /that is subscribed to from inside/ the firewall to come through
> the firewall from the outside.
> The media tools we use have two different behaviors for how they send
> data. For audio the source port for the data is identical to the
> destination port for the data. For video, the source port for the data
> is selected randomly.
> Example of a Secured Static Environment
> This is an example of a small installation configured for a paranoid
> network configuration. The configuration has only three venues to keep
> the example simple.
> To keep this example even more simple, the bridge, data and venue
> server are all running on the same machine, /host.domain/.
> Meeting Room Venue
> Media Multicast Groups Bridge Ports
> static video 224.1.2.3/[1234/1235] 9000/9001
> static audio 224.1.2.3/[1236/1237] 9002/9003
> Laboratory #1 Venue
> static video 224.1.2.4/[1234/1235] 9004/9005
> static audio 224.1.2.4/[1236/1237] 9006/9007
> Laboratory #2 Venue
> static video 224.1.2.5/[1234/1235] 9008/9009
> static audio 224.1.2.5/[1236/1237] 9010/9011
> Venue Server
> * running on host.domain
> * ports: 8000, 8002, 8004, 8006
> *If the firewall is configured to allow multicast through*, then
> Bridge Server
> * ports: 9000-9011
> *otherwise*,
> Bridge Server
> * running on some host with working multicast
> * ports: 9000-9011
> Beacon Service
> * Multicast Group: (233.4.200.21, 10002/10004)
> * Outbound TCP: beacon.dast.nlanr.net:10004
> Summary Configuration
> Incoming *to host.domain* from the rest of the world:
> * /Ports:/ 8000, 8002, 8004, 8006
> * If Bridge Server is *inside the firewall*: 9000-9011
> Outgoing Conduits *from host.domain* to the rest of the world:
> * beacon.dast.nlanr.net:10004
> * If Bridge Server is *outside the firewall*:
> bridgehost.domain:9000-9011
> Multicast Group Conduits:
> All hosts on the local network should be able to send and receive
> traffic via these multicast groups.
> * (224.1.2.3,1234)
> * (224.1.2.3,1235)
> * (224.1.2.3,1236)
> * (224.1.2.3,1237)
> * (224.1.2.4,1234)
> * (224.1.2.4,1235)
> * (224.1.2.4,1236)
> * (224.1.2.4,1237)
> * (224.1.2.5,1234)
> * (224.1.2.5,1235)
> * (224.1.2.5,1236)
> * (224.1.2.5,1237)
> * (233.4.200.21, 10002)
> * (233.4.200.21, 10004)
> Conclusion
> This document describes the firewall requirements for the AGTk 2.0
> software, for both clients and services. For more information please see:
> * The AGTk Home Page <http://www.mcs.anl.gov/fl/research/accessgrid>
> * The Access Grid Project Home Page <http://www.accessgrid.org/>
> * The Access Grid Documentation Project Home Page
> <http://www.accessgrid.org/agdp>
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20031208/4f124813/attachment.htm>
