FW: [AG-TECH] Problems with AG2.1 install
Robert Olson
olson at mcs.anl.gov
Mon Aug 18 12:00:04 CDT 2003
looks to me like he's getting permission denied on his own apsp and
settings directory?
At 11:53 AM 8/18/2003 -0500, Ivan R. Judson wrote:
>Hm.
>-_ivan
> > -----Original Message-----
> > From: Michael Daw [mailto:mike.daw at man.ac.uk]
> > Sent: Monday, August 18, 2003 11:33 AM
> > To: judson at mcs.anl.gov
> > Subject: RE: [AG-TECH] Problems with AG2.1 install
> > > This is certificate/globus initialization stuff; I think
> > Bob's looking
> > > (or can look at this). He'll probably need more information
> > to track
> > > it down though, do you have a log from the client or server you can
> > > send?
> > 'Fraid not. Should I be running something to initialise
> > globus? I seem to remember the last installation procedure
> > (where it wasn't bundled) set it up fine - perhaps install.sh
> > is missing this step? I wasn't running the client or server -
> > I was setting it up on a new machine and was looking for a
> > place to put my certificate.
> > However, if I try to run the venues client, it just hangs
> > (when the bar is about 9/10ths across!).
> > > I'd be happy to help figure out what's going on here, but
> > the log that
> > > was sent was empty. Can you run the tools in debug mode and send me
> > > anything that's coming out in the window you ran them in? That'll
> > > make it possible to track down problems. I suspect it's either
> > > initialization or installation things that have bitten you. Are you
> > > sure you completely removed the previous software before installing
> > > 2.1?
> > I removed AGTk 2.0 and WinGlobus (as instructed).
> > In venue client debug mode, the command prompt shows the
> > following (last page of) output. (I sent it in the error report too):
> > No handlers could be found for logger "AG.VenueClient"
> > 08/18/03 17:29:19 DEBUG My hostname is phoebe.mvc.mcc.ac.uk
> > 08/18/03 17:29:19 DEBUG VerifyExecutionEnvironment: bind to
> > local hostname of ph oebe.mvc.mcc.ac.uk succeeds 08/18/03
> > 17:29:19 DEBUG userConfigDir: C:\Documents and
> > Settings\zzcgumd\Applica tion Data\AccessGrid 08/18/03
> > 17:29:19 ERROR exception opening hash C:\Documents and
> > Settings\zzcgumd \Application Data\AccessGrid\certRepo\metadata.db
> > Traceback (most recent call last):
> > File
> > "C:\Python22\Lib\site-packages\AccessGrid\CertificateRepository.py",
> > line
> > 143, in __init__
> > self.db = bsddb.hashopen(self.dbPath, 'w')
> > error: (22, 'Invalid argument')
> > 08/18/03 17:29:19 ERROR bin.VenueClient::OnInit:
> > WXGUIApplication creation faile d Traceback (most recent call last):
> > File "C:\Program Files\AGTk 2.1\bin\VenueClient.py", line
> > 119, in __init__
> > self.app = Toolkit.WXGUIApplication()
> > File "C:\Python22\Lib\site-packages\AccessGrid\Toolkit.py",
> > line 141, in __ini t__
> > self.gui)
> > File
> > "C:\Python22\Lib\site-packages\AccessGrid\CertificateManager.py",
> > line 24
> > 1, in __init__
> > create = 0)
> > File
> > line
> > 156, in __init__
> > os.rename(self.dir, newname)
> > OSError: [Errno 13] Permission denied
> > > From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
> > > Sent: 18 August 2003 15:52
> > > To: 'Michael Daw'; 'AG Technical Developers'
> > > > Unless I'm doing something stupid (always a distinct
> > possibility), I
> > > > can see several problems with the new AG2.1 install that
> > I'm doing
> > > > this week for SC
> > > > Global:
> > > > 1. The Linux bundle doesn't include rpms for vic or rat (and the
> > > > Audio and Video Service rpms fail as a result).
> > > Frank reported this as well. It's being fixed as we speak (write).
> > > > 2. The Linux install doesn't create a .globus directory for
> > > > certificates. (I can't remember how these got created in the
> > > > previous install. Maybe I answered the questions wrongly...)
> > Bob's looking
> > to track
> > > send?
> > > > 3. There is no icon for Venue Server in Linux on the "Start menu"
> > > > (or whatever it's called in Linux).
> > > There hasn't ever been a icon for the venue server, perhaps you can
> > > file that as a feature request :-).
> > > > 4. I can't seem to start anything on my Windows install.
> > The Venues
> > > > Client stops halfway through starting up and sends an automated
> > > > error report (which I sent); the Venue Server rattles the disk a
> > > > bit, but otherwise nothing; Manage Venue Server flashes
> > up a window
> > > > and then fails.
> > the log that
> > > 2.1?
> > > --Ivan
