wizards and validation
Susanne Lefvert
lefvert at mcs.anl.gov
Tue Aug 12 12:42:35 CDT 2003
Bob,
I am not sure if this is exactly how wizards are suppose to work. I didn't
find a good example on how to combine validators and wizard so this is the
solution I came up with. What event were you thinking about?
/Susanne
On Tue, 12 Aug 2003, Robert Olson wrote:
> Gotcha. If this is how wizards are meant to work, that's fine - I was
> expecting action to be taken on a different event (I didn't use validators
> when I was doing the globus-net wizard).
> thanks,
> --bob
> At 08:56 AM 8/12/2003 -0500, Susanne Lefvert wrote:
> >bob,
> >I added a validate method to each wizard page that is called when a user
> >clicks the next button. For each page, the validate method checks to see
> >if values are filled in as they should be, and for the last page it
> >actually sends the request when the user clicks the next (finish) button. If
> >something goes wrong in the cert request the validation would fail and the
> >user would be notified. Please let me know if you have other suggestions
> >on how this should be handled.
> >Thanks,
> >Susanne
> >On Mon, 11 Aug 2003, Robert Olson wrote:
> > > in my foggy state of mind, it seems unclear that the actual creation of
> > the
> > > cert request happen in a method called Validate; suzanne, can you give a
> > > brief overview of the logic that's going on behind the cert request tool?
> > > thanks,
> > > -bob
