Configuration Document
Robert Olson
olson at mcs.anl.gov
Tue Apr 1 16:48:11 CST 2003
What is the practical difference between them?
At 04:38 PM 4/1/2003 -0600, Ivan R. Judson wrote:
>Is it possible to add two calls:
>GetSystemTempDir() and GetUserTempDir()?
>These are used by various pieces that need to deal with temporary data.
>On linux they should probably both return /tmp, but on windows there are two
>temps:
>Windows\tmp and Documents and settings\user\temp
>Thanks,
>--Ivan
> > -----Original Message-----
> > From: Eric Olson [mailto:eolson at mcs.anl.gov]
> > Sent: Tuesday, April 01, 2003 3:04 PM
> > To: Ivan R. Judson
> > Cc: 'AG Dev'
> > Subject: Re: Configuration Document
> > Added a small table of paths on each platform, and the environment
> > variable that can be used to override them.
> > Eric
> > On Fri, 28 Mar 2003, Ivan R. Judson wrote:
> > > Here's the doc, no interface.
> > > -Ivan
